It's a little tricky to get in that mode on the M9. Press the looper button just before you press the other encoder knob down to get into that mode.
- Report Abuse
Like (0)
Yes, I agree with Line6Miller. You really need to "time" the pushing down of the TAP and Model Select knot to initiate the reset.
I've found it easiest to push the TAP down, hold it but quickly push the Model Select afterwards... but not too long. So, like: TAP (keep holding) and quickly push the Model Select.
You should then see a screen message saying "RESET: Reset to Factory? Are you sure?"
Then, push the TAP + Model Select simultaneously. You won't see anything happen for a few seconds, but if successful, you see a "yellow" Tube Comp FX1A appear again.
- Report Abuse
Like (0)
Actions
- Retrieving data ...
Legend
- Correct Answers - 5 points
- Helpful Answers - 3 points
About
Follow
Subscribe
